How to trigger the Read VI.
Hi Everyone
I configured a DAQ assistant which generates two digital pulses thru 2 counters, and I want to incorporate a Read channel and a trigger in the Block diagram which will trigger the Read just after one of the digital pulses goes Low(Trailing edge) and Read for just 200microseconds.
I tried to explain my best, if you have any questions about clarity please do email me.
Srinath
(3,543 Views)
It appears that this question is being addressed in another forum. Please refer to that forum here.
Matt Anderson
Hardware Services Marketing Manager
(3,512 Views)
Hello Matt
While working on acq&graph voltage-Int clk-Dig Ref.VI,  In the trigger source drop down box, there is a list of some many sources starting with onboard clock,PFI0,....etc, I dont see any one of these on my connector board, then how would i trigger my source. choosing one among the list doesn't help, its giving errors. If i have to choose a trigger from one of the counter or analog input, what should I do. Where can I find extensive help on trigger parameters.
Thank you
Srinath
(3,496 Views)
Hello Sri,
Based on your post here I am assuming you are using the PCI-9281 with the SCB-68 for this task. If you examine the SCB-68 68-Pin Shielded Connector Block User Manual you should find a pin-out diagram on page 1-8 (page 18 of the PDF). This diagram should show you the connections of the SCB-68, including PFI lines. Looking at the M Series User Manual at Figure A-25 on page A-91 the connections should match up.
I hope this information is helpful, please let me know if you have any additional questions.
Matt Anderson
(3,476 Views)
