How to turn LED Red for FAIL and Green for PASS?
Tri-Stated output.
No result = black
Pass = Green
Fail = red
(4,844 Views)
You can use property node for the Led Terminal. Change the node to Color property and wire the desired color.
If you are looking for only two different colors you may choose them by right clicking the LED and selecting properties.
There you will get a chance to select 2 colors one for 'ON' state and other for 'OFF' state.
Let me know if this solves your problem
Regards
CLAD
Using Labview 5.1,6.1,7.1.8.0
(4,838 Views)
Here is a small vi that lets you choose the LED color amongst three colors, using the property node as suggested.
- tbob
Inventor of the WORM Global
(4,826 Views)
I want to see the example for multi-state LED.
Would you please change the above attachment  to LV8.0?
(4,732 Views)
An indicator with more than two states is no longer a boolean, so why treat it as such???
Many examples have been posted here over the years. One possibility would be to use a colorbox indicator made to look like an LED.
For example have a look at my 4ColorLED.vi posted in this thread I am sure you can adapt it for your purpose.
(4,727 Views)
Actually, I need 3 state boolean controller(not indicator).
Have any idea?
(4,721 Views)
You should have read Altenbachs post.  A boolean has two states, on/off or 0/1.  Anything with more than two states is no longer a boolean.  Well that is just a play on terminology.  You want a three state controller.  You can right click on the 3-state LED examples and click Change to Control.  Or you could create an enum with three entries.  Or use this 3-position switch attached.
- tbob
(4,692 Views)
