How to turn a portion of code on and off
Hi Folks,
I have created a VI that will read data from a detector and collate this information in a multicolumn listbox in a hexadecimal format (see attached VI). Now I would like to only collect this data once a "data collection" button is switch on. I have tried to mess around with event and case structures for this, but can't seem to figure this out. Any suggestions as to how I might accomplish this?
I am fairly new to LabVIEW so any suggestions on how to improve my program are also welcomed. Thank you!
(1,551 Views)
Hi Zifikis,
A simple case structure should be sufficient.
Could you save your code for LV2021 (On your VI, go to File -> Save for Previous Version -> 21.0).
When posting code to the forum, ensure it is not in a version superior to LV2021, as lots of users don't have higher versions installed (for various reasons).
Raphaël.
(1,534 Views)
Hi Raphaël,
Good to know. I have now attached the 21.0 version.
Zifikis
(1,514 Views)
Accepted by topic author Zifikis
Attached is an example where I put the building of the data array in the case structure.
I also disabled the VISA part and added random generation of data to allow anyone to test the VI.
I also recommend that you check the available VISA examples:
Go to Help -> Find Examples -> Search "visa serial" -> Open "Continuous Serial Write and Read.vi"
Raphaël.
(1,493 Views)
Your suggestion got the VI to work as intended. Thanks for taking a look at this.
(1,481 Views)
