How to turn off scroll bars in SubPanel
In LabView 2010F2, I have some SubPanel controls that insert the Front Panel of a VI that is larger than the SubPanel area. This makes Horizontal and/or Vertical Scroll bars appear.
Is there a way to turn off these scroll bars so they will not appear?
(5,568 Views)
(5,560 Views)
Go to the Front Panel of the VI that opens in the sub-panel.
Right-click on the scroll bar and select Scrollbar Horizontal and select Always OFF
Repeat the same step for Vertical Scroll bar.
Run the VI with the sub-panel and the srcollbars should be gone.
(5,559 Views)
@smercurio_fc wrote:
Did you try a search?
http://forums.ni.com/t5/LabVIEW/How-to-remove-sub-panel-scrollbars-with-LabVIEW-2009-SP1/td-p/127855...
It applies to 2010 as well.
LOL!  I should simply have linked to my own post, but I was in the mood to type something. 😉
LOL!
Thanks SMercurio
(5,558 Views)
