How to uninstall a LabVIEW patch
So we have plenty of systems running LV 2014 (x64) f2. But we found a bug in f2.
How do I remove the patch only ?
When I go to patches nothing shows up.
When I did a repair install and used the LV 2014 (x64) 14.0.0 installation download, it took an hour, booted back and when I go to the about ... i see I'm still running f2 ...
Maciej
(4,292 Views)
Interesting, I had a quick look and tried the same things you mentioned, I have no patch to uninstall but my next try would be to download the specific patch installer, and see if it can uninstall itself.
Jimmy
(4,261 Views)
When I try to use the patch distribution I get the
"This is not a valid distribution location. Please select another location and try again."
Am I to understand that you had f2 , ran the 14.0.0 installer and ended up with LabVIEW 14.0.0 ( no patch )?
(4,247 Views)
