How to uninstall corrupted NI Measurement & Automation Explorer?
I have problem to install LabView 2012 and all components, cos I didn't uninstall my previous version (2012) properly.
I have LabView_Fall_2012 and NI_Device_Drivers_August2012 and Win7 x64. (try to install it on non OS partition).
Now when I try to install new I get "NI Measurement & Automation Explorer 5.3 (higher version already installed)" and installation ends there.
My aim is to install everything if possible than uninstall it properly and then install it again. Now I manage to remove most of the files, reg entries and stop services but some things are still left.
What have I to do to make installation to processed?
Its possible to remove all files/reg manually?
There is one file which cannot be deleted "C:\Program Files (x86)\National Instruments\Shared\mDNS Responder\nimdnsNSP.dll", its possible to remove it?
Thanks a lot for your help
(12,362 Views)
Accepted by topic author pumadace
IMHO there are two options:
1. Try to install MAX 5.4 again, download here
2. The DLL ist used by the Update Tool from LV. You can delete it using this tool: Unlocker
Stefan
(12,340 Views)
Thank you so much for quick reply.
It worked.
I didnt know it was this simple.
With unlocker I have some issues because of my antivirus system but after uninstalation it could be deleted normaly.
(12,315 Views)
