How to up convert the number of samples in a waveform
Hi, I have acquired an analog and a digital signal at 1S/s for 10 s . So I have 10 analog samples and 10 digital samples. Now I would like to upconvert the number of samples of the acquired signal to let's say 10kS/s . How can I
do it in labVIEW for the analog and digital signals?
I don't want to change the duration but let's say I have a zero , I would like to make it 10000 zeros.
(3,585 Views)
Hi tintin,
there's a function named "ResampleWaveform"...
Btw. what's the point in upsampling by a factor of 1000?
(3,579 Views)
The LabVIEW math palette has a rich set of interpolation tools that you can apply to the Y data (then you also need to change the timing information).
Alternatively, there is the Align and Resample Express VI that could do about the same thing.
(3,575 Views)
Well, I am not actually acquiring the signal. I build the signal at 1S/s but finally I need to change the sampling rate to somthing else. I think the easy way might be to take the Y array and of r each element add ( lets say 100 elements  if the sampling rate is 100) but how can I do it in LabVIEW?
how can I do this in LabVIEW
Lets say the sampling rate is 5
123
111112222233333
(3,570 Views)
A simple Initialize Array inside of a FOR loop with concatinating tunnels works well.  The concatinating tunnels became available with LabVIEW 2012.
(3,558 Views)
