How to update FPGA Reference inside Case Structure?
How do I update the FPGA References that are inside of a Case Structure? When I change/re-compile the FPGA VI, the references do not update.
Context:
I am building a 4-axis machine that uses the FPGA VI to monitor position switches. I have built an action engine for each axis comprised of a Enum Case Structure inside of a terminating While Loop with all pertinent information retained on un initialized shift registers.
Details:
I have one Case that initializes the communication and uses "Open FPGA Reference" to put the FPGA VI Ref onto a shift register. Subsequent Cases use that FPGA VI Ref to transfer information. Works well. However, if I need to edit the FPGA VI and re-configure the "Open FPGA Reference" to that VI, the following items (e.g. FPGA I/O Node) do not update with the new information.
The Nodes will update if I move the "Open FPGA Reference" in front of the While Loop, and open/close everytime the loop is called. However, that ends the FPGA VI.
Is there a better solution? Am I missign something?
THank you in advance for your help
-David
(3,082 Views)
Hi David,
create a typedef for the FPGA VI reference. Then instruct "OpenFGPAReference" to use that typedef for all times…
(3,057 Views)
