How to update front panel immediately with any control change in LabVIEW7.0?
I have a lot of controls on the front panel. I want my 3D plot to be updated with any of them changed. Currently only one control's change can result in the update even if I do have done changes on other controls .. that's to say, only one specific control's change can activate the front panel updating ... That's not what I want. So how to make the front panel updated immediately like VC?
Many thanks!
(2,780 Views)
I solve this problem by combining the event structure with a classical state machine. The classical state machine is a case inside a loop with either an enum or string shift register defining the actual state. In the idle case of that structure is the actual event structure which handles the UI.
Whenever I need to trigger a specific action which could happen from multiple locations I actually place the handling code in a specific case in the outside state machine and just wire from the actual event case the according state out to the shift register.
This architecture allows for a very flexible and extende state machine programming with the event structure doing all the UI event handling and the state machine doing the more involved actions or series of actions
Rolf K
Rolf Kalbermatter  My Blog
(2,780 Views)
