Hope this is a good bone, I’m throwing.
Your package labelling is just like the one I use for LV2.2 Mac to LV6i. The file dates are old because you basically have early/mid 90’s versions of LabVIEW on your CD.
The problem is that GB drives weren’t prevalent back then and I think LabVIEW miscalculates what your real free space is.
Try this:
- Copy the conversion folders (lv311, lv401) to your HD.
- make sure the labview.ini file in both copied folders is not set to ‘Read Only’ (I had to change the one in \lv401).
- add the following to the labview.ini file for both versions: checkAvailDiskSpace=False
Hope it works.
Fading out. " ... J. Arthur Rank on gong."
