How to upgrade system from serial communication to parallel communication
Hi
Thanks Coq rouge . I never said that it is a labview problem, I asked if i changed serial communication to parallel how much my communication Vi will change.
you understood my problem correctly. Thank you for your advice but i did not understand if m connecting more 4520 adam cards ,say for each ADAM card. I will be able to access
all inputs at a time ,but then how i should transmit data on a unique communication line? Each card will be connected to separate 4520 right?
GAK
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
Message 11 of 12
(557 Views)
If you want to poll N serial devices in parallel, you need N serial ports. In this case you need 7 RS-485 ports, one for each ADAM I/O module.
Paolo
LV 7.1, 2011, 2017, 2019, 2021
Message 12 of 12
(551 Views)
