How to upload data from thingspeak to labview?
I am using thingspeak to output my data into graphs and charts, however, is there anyway to export the data from thingspeak to labview?
(8,322 Views)
I would think that LabVIEW's HTTP client VIs would do the trick for you. Apparently ThingSpeak uses standard HTTP as the interface mechanism, but when you access ThingSpeak instead of it returning a web page, it returns a chunk of data.
You will of course need to convert the string representation of the numbers into numeric representations, like in the MATLAB examples.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(8,310 Views)
Can you please made an example or a tutorial to how to make it using Labview for both raed and write.
(7,732 Views)
This example shows the http get in combination with a thingspeak channel.
(7,359 Views)
thank you (and kudos) for sharing this VI Roland.  It helped me figure out my type mismatch error during unflatten from json while reading data from thingspeak.  I also had to make my channel public in order to get the connection.  I have my user and pass in the openhandle block but i kept getting a bad response.
(5,602 Views)
Thanks a Ton
(4,987 Views)
Is there an MQTT Thingspeak example ?
(4,024 Views)
