How to use Alarm and Event Display indicator from DSC palette on the front panel
Hi everyone,
Please I will need help on the following problem I am having on using Alarm and Event Display control on front panel.
I have configured data logging: log alarms and events and also alarming for my shared variables on the project explorer. I then placed the alarm and event display indicator from the DSC palette on the front panel.
I then run my VI expecting to see a displayed message on the alarm and event display control but nothing showed when my alarm set point was reached.
Please how can I make these alarms to appear on the Alarm and Event display indicator on my VI front panel.
Thanks you.
(2,786 Views)
It might be a good idea if you post your project here on the forum so that we can have a look at it.
Further from that, it is worth checking out some examples to see how it is configured.
The shipped DSC Alarms Demo.lvproj is probably a good place to start.
Also check the help file for useful info:
http://zone.ni.com/reference/en-XX/help/371618D-01/lvdschelp/view_almevt_dis/
Best Regards,
Nick
(2,736 Views)
