How to use Butterworth filter in myRIO 1900
I am reading force sensing resistor (FSR) and single axis load cell data using myRIO inside a timed loop running at 10,000 Hz. I wanted to filter these data to remove noise using Butterworth filter. I don't know how to use it. Please help me on the same.
(3,007 Views)
Hi srikesh,
Apparently you know how to use them - they are already in your code…
So what is the real question/problem here?
Did you read the LabVIEW help for that filter function? Did you wire ALL inputs as needed?
(2,994 Views)
Apparently. I don't know about the other inputs that are required to be provided to the filter like sampling frequency, low cutoff, and order.
(2,990 Views)
Hi srikesh,
You wrote you run those functions in a loop at 10kHz: this would be your sampling frequency. (Do you really run this at 10kHz?)
Cutoff frequency and filter order depends on your requirements: you should know them. In fact you should know your requirements before even starting to code! And you should know the basics on filter functions: I guess you have some books at hand or are able to use Wikipedia…
(2,986 Views)
Yes, I do run it at 10 KHz.
(2,976 Views)
