How to use DSC & OPC with mitsubishi PLC FX2N
Hi I have  PLC of Mitsubishi FX2N /FX3U
Communication board is FX 232 BD.
Data register in PLC  D8120  For serial communication.I want to use this type of PLC with DSC & OPC 8.5 version but, I am not able to communicate this PLC with DSC as I want to use this to control hydraulic test stands.Also guide how I can use DSC for data acquisitions.Support india is trying this from last 2-3 weeks still they are not able to slove the problem so kindly help asap.
Regards
Nitin Badgujar.
(5,888 Views)
Labview application to Mitsubishi PLC communications, No Mitsubishi PLC OPC Server to communications.all the labview vi write....
We are finish it
see at
http://www.abb-furnace.com/scada-system/labview-mitsubishi-fx2n-plc.html
x_y_z_88@hotmail.com
2009911@gmail.com
Labview Applications Engineering
Labview SCADA/HMI Systems
Labview AB Rockwell PLC, Omron PLC,Mitsubishi PLC,Siemens PLC,Fatek PLC,Delta PLC
Labview Vision, Vision Builder
Labview Profibus,EtherNet/IP,EtherCAT,DeviceNet,Canopen
http://www.abb-furnace.com/scada-system/scada-system.html
(3,799 Views)
