How to use G Web server database access from context menu?
When I select Enable Database Access from the context menu of the G Web Server, the icon changes and new ports are added.  Where can I find out about that functionality?  Are there any examples that demonstrate the use of the server in this mode?
(2,728 Views)
Hi Kc64,
Please go to LabVIEW Help and search for "Enable Database Access", and you'll find out what the Enable Database Access functionality is for.  Read the Retrieving Logged Front Panel Data Using a SubVI.  It basically logs front panel information output from a subVI to a database.
Yi Y.
http://www.ni.com/support
(2,708 Views)
