> I try to use a DLL to control a unit plugged in my COM1. This DLL use
> setLastError in kernel32.dll but when i use GetLastError i have 0 : no
> error. I thing that the thread that is taken by GetLastError is the
> run-time of Labview (that has no error) and not the thread of the
> DLL... not easy to explain in english...
> If someone can help me .. ?? don't hesitate !!
If possible, it would be better if the function returned the error for
you, as GetLastError is a poor way of doing this in any API.
In the default settings, it is a little difficult to control which
thread executes various subVIs or DLLs and in which order. You can
arrange it to be predictable, though.
I think you have two problems. First off, you want to make sure that
the same th
read calls the function that sets the error and GetLastError.
The utility for setting threads is in
vi.lib/utility/sysinfo/threadcfg.vi or something close to that. It will
indicate how many threads are setup for a given execution system and
priority. You could arrange for any of these to have only one thread
and then make sure the VI running the nodes runs in the execution system
with only a single thread. You could also just set the DLLs to run in
the UI thread.
The second problem is that after executing a node, LV can switch over to
run a different node, then switch back at a later date. During this
switch, another VI can call SetLastError, GetLastError or
ClearLastError, all of which affect the thread-global error state. So
you need to arrange for the nodes to run such that nothing separates
them. One way of doing this for certain is to make a wrapper DLL around
the calls such that the calls happen in a synchronous DLL, where LV
cannot do switching between t
asks. If you have already setup a VI to
run in a less used execution system, and nobody else uses the thread,
then you are good to go.
Greg McKaskle
