How to use Image field in SQL-7 for curvs
I sampling data from a NI-card. There will be a lot of data so I thought I should use Image-field in SQL-7 to save the hole curve. How do you do that?
(2,580 Views)
I would suggest looking into the Database Connectivity Toolset. It has complete SQL functionality and uses ADO to connect to many types of databases. I have it and it comes with example programs which demonstrate how to write to and read from databases using SQL.
J.R. Allen
(2,580 Views)
