How to use LabVIEW to download a 4MB zip file from a web site?
I have the internet toolkit.   I can't get it to download a 4 MB zip file from a web site.   Has anyone done this?
Brad Whaley
Module Test Engineering
Intel Corp.
Brad Whaley
LabVIEW Certified Engineer
(3,918 Views)
There is a way to do it using Datasocket.  Check out this thread:
http://forums.ni.com/ni/board/message?board.id=170&message.id=49746&query.id=2214#M49746
I tried it with a zip file and it worked.
Good Luck
maat
LV2019
(3,897 Views)
You can use the URL Get HTTP Document VI. Feed a full path (with the file name) into the appropiate input and it will save the zip file to that path.
___________________
Try to take over the world!
(3,885 Views)
Ah Ha! Adding the filename to the path input made the "URL Get HTTP Document" VI work for me.
Thanks tst!
(3,364 Views)
Hi all,
I have the same problem, but i am not able to fix, can you attach an example? thanks
(3,189 Views)
