How to use Labview to output the coordinates from Pattern Matching result
I tried to add some labview commands into the vi program created by IMAQ Pattern Matching scrip to output the coordinates of a target point found in Pattern Matching because i need to do some calculations for the point coordinates and I don't want just to read the values from the IMAQ results on the monitor. Does anyone can help me? Thank you.
(2,845 Views)
I have posted replies to your other postings with your same question, and continue to recomend that you look at some of the LabVIEW tutorials.
I modified the attched program such that it would index the arrays of match information returned and then unbundle the X and Y features of the match and add them to gether as an example of how to access the data programatically.
I hope this helps.
Amaury Rolin
NI Applications Engineer
(2,845 Views)
