How to use .NET method with OutAttribute parameter from Labview
I am trying to call a .NET Assembly method from Labview which has the following signature in managed C++,
bool ReadInfo ( [InAttribute] int mobileIndex_, [OutAttribute] Double& fer_, [OutAttribute] Double& ser_);
I can call the this method from other .NET client program (e.g. TestStand) with no problem. In Labview I see the OutAttribute parameters as .NET refnum and I cannot seem to get the values passed back from my assembly.
(3,165 Views)
This is a known problem in LV 7.x. You are going to need to create some simple accessor methods in the .NET language of your choice I am afraid.
Here is the original thread...
http://forums.ni.com/ni/board/message?board.id=170&message.id=115883
(3,153 Views)
