How to use NI USB 6361 generate TTL/CMOS digital output?
Hello - I am trying to use NI USB 6361 to control a CMOS device with digital inputs 0.8V to 2.4V logic thresholds, but cannot find any place to set the output digital signal from NI 6361. Anyone knows?
Pem
(2,763 Views)
The Digital IO is TTL only.  You'll need to use a level shifter circuit to convert to CMOS.
EDIT:  Found a TTL <> CMOS tutorial that might interest you:  http://www.instructables.com/id/Level-Shifting-Between-TTL-and-CMOS/
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(2,746 Views)
