How to use NI XNET to read CAN data when import a dbc file?
Hi,ALL
  Then,I want to know how to USE NI XNET to read CAN data when I import a dbc file?
  Thanks!
(4,608 Views)
Associate your database file with your xnet session. Then use XNET Read.vi.
(4,573 Views)
Yup basically.  There are several installed examples when you install XNET under Help >> Find Examples which shows just about all the basic tasks you'd want to do with CAN.
(4,567 Views)
Yes,and I just try these samples,but these just read dbc files. Then I don,t know how to use dbc files to read CAN data?
(4,560 Views)
After performing an import, you no longer use the DBC file, you use the XNet database.  You still haven't explained what you are trying to do.  You can't read CAN data with a database, you read CAN data with CAN hardware.  Explain where the data is coming from, what it looks like, what you want to do with it, and how it relates to the DBC file.
(4,526 Views)
