How to use RS232 to get data from PIC
HI
Thanks for the files.
Attached you will find what I did so far. Now the communication between the pic and Labview works.
The only problem I do have now is that the gauges tend to jitter.
I wonder If I made a huge mistake in the programm or that Labview is just not fast enough for that.
I do get a new inputstring every 100ms. When I change the constant of the waittimer it becomes better. But I think that is not the right way to get acceptable values.
Bye
Message 11 of 15
(1,456 Views)
I am unable to look at your code, I am still working with LV 7.0 and I think you sent 7.1.
I take it you are making an analog measurement with your PIC.  I have that problem too as in my program I am using 10 bits to take in a 5V reference.  Check and see if you are using 8 bits or 10 bits, the code would be
#define ADC = 10
if you don't see this line, you are using the default and it is probably 8 bits.  But still that would be 19.5 mV separation at the PIC input.  I am using a cheap potentiometer as well as 10 bits so I expect some jitter with 5mV separation.
As for speed, I had my baud rate up to 38400, continuously taking in data and never had any problems (generally I operate at 9600).
My guess is the jitter is coming from the PIC, I haven't done a lot of programming in LV or PIC's but I hope to do more in the future.
Message 12 of 15
(1,440 Views)
wiring diagram please
Thx
Message 13 of 15
(717 Views)
To whom is your question addressed? And to what are you referring by "wiring diagram"? If you are referring to the block diagram, the VI was posted - just download it and look at it.
Message 14 of 15
(712 Views)
I want to say electronic circuit diagram
Message 15 of 15
(688 Views)
