07-26-2005 06:47 AM
07-27-2005 09:30 PM
Hello Kousy,
The Offset just specifies where to start reading information from in the file. If you want to retrieve all of your data then you can just leave the input blank and it will default to 0, which means that it will start reading from the beginning of the file. I hope this helps!
Chris J
