How to use Windows Virtual-Key Codes with Special Characters such as $
I'm developing a Keyboard for a Touch Screen Windows 7 application and I need to have access to Special Characters such as $ % ^ and others but I can't find a way to use them from the Windows Virtual Keyboard. I'm using the following example which has all regular characters you can find on a keyboard.
https://decibel.ni.com/content/docs/DOC-9001
Also I'm using information from the following MSDN documentation:
https://msdn.microsoft.com/en-us/library/windows/desktop/dd375731%28v=vs.85%29.aspx
The problem is that the Windows On-Screen Keyboard is able to type these special characters but I can't find their VK codes to use within LV.
Does anyone have any idea on how to do it?
Thanks and regards.
Luciano Borges
Test Development Engineer
(5,173 Views)
Hello Luciano,
I read the MSDN documentation and I understand that VK Codes reffer to keybord keys and not to keyboard characters, so if you need use a character that require combine more than one key you need code the combination that provide the disired character.
We also have a KB about it.
http://digital.ni.com/public.nsf/allkb/15D9EAAE7AF1132586256FB70066E0DD?OpenDocument
Best regards.
Abel Souza
Engenheiro Eletrônico
LabVIEW User since 8.5
(5,115 Views)
Hey Luciano,
Why don't you try calling the on-board screen, which is native to Windows.
I made a simple VI that you can use as a base code for your application. Give it a Try!
Best Regards.
Felipe Flores
Technical Support Engineer
(5,095 Views)
