How to use a LabVIEW 2020 driver on a LabVIEW 2019 engine?
I have an equipment that uses labview 2020 drivers but I have labview 2019. Is there a way to use/convert the drivers?
(1,680 Views)
Do you want to open a library written in LabVIEW 2020 in LabVIEW 2019?
You can Reverting LabVIEW Files to a Previous Version
https://tmesystems.net/
(1,668 Views)
Hi ZyOng,
I can't open the library because it was the file I am trying to open is for a newer version of labview which I don't have. What should I do? This is the labview driver below.
(1,661 Views)
Accepted by topic author Teekayy
You could post a request on the Version Conversion board.
In your case, you could simply download an earlier version from BK Precision 913XX Power Supply - USB, IEEE 488.2 (GPIB), Serial Driver for LabVIEW
(1,649 Views)
Gotcha ZYOng,
I believe the NI version doesn't have 9130C listed for the supported models but I did post on the Version Conversion forum.
Thanks for your help!
TK
(1,644 Views)
