How to use a Matlab Program within Labview
Hi
I saw in this forum that many users are using some matlab program executed in Labview program. I have actually Labview 7.1 and would like to use some of my matlab program in Labview. Is there an easy way to do it ?
Thomas
(3,231 Views)
There is a "matlab script.vi" ,just put it on your block diagram,and add some input and output variable,then you can make matlab program just like what you did in matlab m-file editor.
(3,223 Views)
The MATLAB Script function is kinda buried in the function palette, and can be found under Functions >> Analyze >> Mathematics >> Formula.  Unfortunately this feature is not available in the LabVIEW Base package.  Hope this helps!
Andy F.
(3,203 Views)
Thanks for help. I found the script with difficulty in the palette (the path is not written in the help) but it seems to work fine, at least for simple programs.
Thomas
(3,199 Views)
