How to use a variable within a loop with NXT/EV3 robot?
so i basically want to be able to have a variable/constant created outside of a loop, changed within a loop, and remain change through iterations of the loop.
for example, if i create a value of 10 outside the loop and i want to increment by 1 inside the loop until a task is finished, i don't understand how to do this.
I'm trying to understand how to do this in order to make my robot move more smoothly, so for example instead of putting a constant value into the power of each motor i could instead have the power be flexibly changing depending on differing conditions. i.e if robot realizes its near the edge of a table it can smoothly change power values to make a smooth turn instead of braking and then turning.
Thanks!
(4,200 Views)
(4,189 Views)
