How to use advanced TDMS file read .tdms
I have a .tdms file that is automatically stored using 'DAQmx configure logging (TDMS) vi'.When I read with normal TDMS, the data can be read correctly, but when I read with advanced TDMS asynchronously VI, it can't be read properly, the data is wrong.I've been debugging for a long time and I don't know what the problem is.Everybody ace, have who can help me look, very grateful!
(3,503 Views)
Please don't attach VI's that use Chinese or Japanese characters.  Only English characters.
Only Japanese or Chinese PC's can handle that font.  The VI won't open on an English PC.
(3,416 Views)
I was able to open your VI after rename it.
But group and channel name are also in Chinese.
Got invalid group/channel error.
George Zou
(3,395 Views)
Hi,RavensFan
          Thanks for your reply.  Now,I changed the VI to English. Would you please help me find out what the problem is ?
(3,374 Views)
Thank you,George Zou
        I changed the VI and .tdms file.Please help me find out the problem,thanks a lot!
@zou  已写:
(3,367 Views)
Did you try this example:
C:\Program Files (x86)\National Instruments\LabVIEW 2015\examples\File IO\TDMS\Advanced Read and Write\Asynchronous Read and Write\TDMS Advanced Prefetched Asynchronous Read.vi
George Zou
(3,356 Views)
Hi,George Zou
     I used the TDMS Advanced Prefetched Asynchronous Read.vi。The problem still
exists。
@zou  已写:
(3,331 Views)
