How to use case structure
Hello I am new to LabView. I am trying to use case structure to find 2 different values. when it is on the left I want it to calculate something and when it is on the right I want to calculate different thing with same values. I dragged the case structure and i connected it to boolean(Rocker) . But, i dont have any idea other than this. Should I drag the equations inside of it?I am completely lost. thank you
(3,185 Views)
Drag what equations? To answer your question, yes, you would put the code to perform the specific action to perform when the case is true, or when the case is false. Have you done the tutorials? Your question is an extremely basic and fundamental one.
To learn more about LabVIEW it is recommended that you go through the tutorial(s) and look over the material in the NI Developer Zone's Learning Center which provides links to other materials and other tutorials. You can also take the online courses for free.
(3,177 Views)
