07-16-2008 01:31 PM
07-16-2008 01:48 PM - edited 07-16-2008 01:49 PM
07-16-2008 02:07 PM
But by creating a custom control/indicator don't you slow things down compared to passing information along "wire" created by a cluster?
Trying to Humm effeciently.
07-16-2008 02:29 PM
07-16-2008 03:00 PM
I found the "cluster" for the controls. You just put a cluster on the front panel, resize it to be big enough to include all the clontrols you want to have in it...move the controls inside and presto...the controls are included in any bundle/unbundle by name. If you drag another control into the cluster, it gets included too.
That's neat...too bad its not explained that way in any of the LV documentation.
I have included an example to be sure I got it right...any thoughts?
Thanks a bunch for the help.
Hummin' along again.
07-16-2008 04:10 PM
07-16-2008 05:37 PM
Thanks...that is all absolutely correct and very helpful.
I was using clusters on the block diagram (without any use of them on the front panel) by bundeling named Control values ... just as a learning exercise. I noticed the values of the output being 0 if the reset button had not been pressed and assumed that was the default value of any variable if it had not been written...(bad assumption sometimes which you have reminded me of...great.)
Thanks for the tip on the autosize.
This should really help clean up my "code" ... "drawings" ... "diagrams" that's it.
Now I'm really embarassed about some of the stuff I "drew" a month ago...but it is all working so will fix it carefully.
This forum has been a great resource and I want to thank you for taking time to help me.
Hummin.
