How to use cursors on Smith Chart?
Hi everybody,
    Last 7 days , i was trying to point some markers on Smith chart.
Please suggest any method to implement this. i want to mark some points on smith chart and get data.
thank you,
dg7318
(3,545 Views)
@dg7318 wrote:
Hi everybody,
thank you,
dg7318
labview\examples\picture\demos.llb for an example of using the Smith Plot VI.
(3,520 Views)
thankyou nyc,
I am seeing the demos.llb but nothing is mentioned about using cursors or markers.
I am plotiing impedance on smith chart. I want to put some markers on the chart. I also want to control the placement of those markers. I wish to get data (impedance and frequency) wherever the marker is positioned.
Again thanks for ur help.
dg,
the things that seems to be impossible first, after completion gives u real happiness..
(3,500 Views)
Accepted by topic author dg7318
Got the answer, first we have to make the marker (a cross, a triangle or some other shape), then we have to change its location by changing index of impedance array. So for each index the marker will have a specific R and X values, which will be as per requirement
dg7318
(3,370 Views)
I saw this thread and it is marked as resolved. I am also trying to do the same thing and couldn't find anything related from NI. Is it possible to share what you did to place markers on Smith Chart?
(1,678 Views)
