How to use dsn file, connect to mysql
Refer to the snapshot, the profile" Test" is okay, use odbc 8.0 driver to mysql 5.7
But when i call it in labview, report errors:
NI_Database_API.lvlib:DB Tools Open Connec (String).vi->Check MAC Status.vi<ERR>ADO Error: 0x80004005
Exception occured in Microsoft OLE DB Provider for ODBC Drivers: [Microsoft][ODBC Driver Manager] The specified DSN contains an architecture mismatch between the Driver and Application in NI_Database_API.lvlib:DB Tools Open Connec (String).vi->Check MAC Status.vi
Could any body give some comments ?
Thanks.
Keep moving
(2,245 Views)
Already fixed the issue, use the dsn file to access the mysql.
Thanks.
Keep moving
(2,194 Views)
