How to use labView to measure temperature using a thermistor
I'm trying to create a labView that will give a temperature reading based on a circuit using a thermistor. Any ideas on the VI or how to construct the circuit would be helpful!
(4,693 Views)
Well, you need to generate a voltage. You also need a way to read that voltage. Do you have a meter, or a DAQ device?
Temperature Measurements with Thermistors: How-To Guide
As for other circuits, the internet is a good place to search. Have you tried? Here's a couple of places:
http://www.discovercircuits.com/T/therm.htm
http://www.facstaff.bucknell.edu/mastascu/elessonsHTML/Sensors/TempR.html
http://www.ecircuitcenter.com/Circuits/therm_ckt1/therm_ckt1.htm
(4,689 Views)
Yes, I do have a DAQ and power supply to generate the voltage.
(4,684 Views)
Then you should have what you need. Read the information above and return if you have further questions. Smiley Wink
(4,679 Views)
