How to use labview adaptive filter to predict and then control the output of unknown system? ? ?
After using the labview adaptive filter to identify an unknown system, is the output signal obtained by passing an input signal through the filter equal to the output signal obtained by the input signal passing through the unknown system?
How to design a block diagram, input signals to an adaptive filter, and then get an output signal, which is equivalent to the output signal obtained by the same input signal through an unknown system?
which kind of function is supposed to be used?
How to use labview adaptive filter to predict and then the output of unknown system? ? ?
Message 1 of 1
(2,127 Views)
