How to use math formula on waveforms
Hi all,
I'm trying to create a program that can use math scipts, formulas etc on waveforms. I've done it for one signal, but I don't know how to change work on 2 or more signals;/ Let's see exampe: one channel is voltage, the second is current and I want to see both of them and as a third signal power so I'm writting formula ch3=ch1*ch2. Another example: I've signal which represents speed of starting motor (500 points) but I need only few points so the formula will be: ch1(20:120) and I have points from 20 to 120. Is it possible to do it? I can't do it using blocks cause I don't know which signal means what... so ch1 can be voltage, ch2 speed, ch3 current ch4-torqu etc. I know that I can cut a part of signal by subarray or subwaveform but it must be done by formula to use (for example) something like that:
ch1(1:20)=0 <- replace all point from 1 to 20 of ch1 by 0
ch2(50)=40 <-replace point 50 of ch2 by 40
ch3=ch1*2 + ch2 <- do this operation but first do both above this one.
Is it possible? or it's to complicated?
I attached my vi which is working for one selected signal (I don't want to select it... but I don't know how to do it;/) and signal that I'm using to check how it's work
Mike
(5,655 Views)
I've upgraded it a little and it works with 2 signals but very sensible;/ formula must have this construction: c3= ... , both of signals must be switched on, there's no way to use part of signal (e.g.c1(21:54) ) and I can't use 2 rows (something like this: c3=c1*c2; c3=c1 doesn't work);/ additionally I wanted to have possibility to use all of signals as input and all of them as output
(5,635 Views)
edit:
I forget to save vi for previous version
Now I attached my vi for LV 8.6, and I hope now someone can help me:)
(5,618 Views)
Your small express VI that converts the blue dynamic datatype wire is wrong.  You have it set to convert to a single waveform, thus the reason you are only getting one waveform.  Change it to be a 1-D array of waveforms.  Now you can use index array to get at each waveform individuallyk.
(5,609 Views)
Yes, but when I change it I can't connect it to "Get Waveform Components" ;/ this problem is just addition to my general problem - how to make formula more advanced etc - my first post in this topic
(5,593 Views)
Because then you have an array.  As I said, you need to use index array to get each individual waveform out of the array.  Then you can use Get waveform components on the output from the Index array function.
(5,590 Views)
