How to use mouse wheel to move the array's scroll bar when running?
Can I make it without using the Event Structure and as easy as possible?
Thank you.
(2,875 Views)
You don't need to do any code for that. Just keep mouse pointer anywhere inside the array and use the mouse scrollbar. Remember you need to enough elements to scroll up-down.
(2,866 Views)
Hello Anand,
Thank you for your reply. I have tried and it failed.
You can use the vi attached to have a try. It doesn't work when it run on my computer (LV 2010).
(2,854 Views)
