How to use "GetLastInputInfo" in "user32.dll"
I need to logout user if he doesn't make action during 5 minutes, "GetLastInputInfo" method in the "user32.dll" library, return the tick of the last action, so I can know the inactivity time of the login user.
But I try to using "Call Dll function" item in Labview 8.1, and each time I run VI, Labview crash.
Next, is information about the method :
DLL
User32.dll
Syntax
BOOL GetLastInputInfo(PLASTINPUTINFO plii);
Parameters
plii : [out] Pointer to a LASTINPUTINFO structure that receives the time of the last input event.
Private Type LASTINPUTINFO
    cbSize As Long
    dwTime As Long
End Type
Return Value
If the function succeeds, the return value is nonzero.
If the function fails, the return value is zero.
Remarks
This function is useful for input idle detection. However, GetLastInputInfo does not provide system-wide user input information across all running sessions. Rather, GetLastInputInfo provides session-specific user input information for only the session that invoked the function.
You can see also my VI source.
(8,117 Views)
Change your calling convention to "WINAPI". You have to use this calling convention when calling Windows API functions.
Note: Depending on how you have it set up you may be able to just use an Event Structure's Timeout event.
(8,114 Views)
Oki for WINAPI, but it doesn't work anyway, Can you explain me what is an "Event Structure's Timeout event". Maybe you can make a little sample. Thanls.
(8,102 Views)
Hi SebBourgeois,
now it works, see the attachment.
Mike
(8,091 Views)
When you place an Event Structure on the BD, by default it ll show the Timeout event. Smiley Happy
If you rt-click on the ES border & tell Edit Events handled by this case..., you can see that this Timeout event is owned by the application itself, not by any individual control/indicator present on the FP of teh VI [Application].
- Partha ( CLD until Oct 2027 🙂 )
(8,089 Views)
Thanks a lot, now I know how to get a Cluster size wich is my real trouble.
(8,083 Views)
Use the All Objects[] or teh Controls[] property of the cluster to get that array of all the controls/indicators inside a cluster & wire this to the Array Size function to get the size of the cluster. Smiley Happy
(8,074 Views)
