How to use "Select Signals" Express VI with consistant plot colors for each input?
Hi alyeska,
It seems like you need to set the active plot to bind it to a color before changing the visibility.  If you do this, I think it will fix your problem.
Eric V
Certified LabVIEW Associate Developer
"I'm a Ramblin' Wreck from Georgia Tech and a helluva (NI Applications) Engineer!"
Message 11 of 12
(701 Views)
Eric and David,
I have confirmed that setting "active plot" first in each property node does in fact make this work as I expected!
Thank you very much for your assistance!
Message 12 of 12
(699 Views)
