How to use single Timer to generate PWM PULSE, Pulse ON time measurement, Event time measurement1,Event time measurement2
I am planning to use a single Timer to generate PWM PULSE, Pulse ON time  measurement, Event time measurement1,Event time measurement2 some one please suggest me how can I achive this.
Thanks in advance..
Michael
(2,900 Views)
Can you elaborate more on that please. It's not clear what you are trying to achieve.
B.
Benoit Séguin
Software Designer
(2,885 Views)
Hi Michael,
It would be really good to understand your application a little more so that any specific needs that you have may be met. In the meantime, I would also suggest searching on ni.com for "pwm" or other keywords that relate to your application. You will see a faceted navigation on the left side that allows you to narrow your search for example code, tutorials, etc.
Please post back with more information and the community will be able to help out with suggestions.
ni.com search for "pwm"
Mark E.
Precision DC Product Support Engineer
(2,872 Views)
