How to use the Controls / Indicators in both forms?
I wonder if there is some method in which I CAN USE A NUMERIC CONTROL IN WHICH I INSERT A DATA LV PROCESS THIS DATA AND THEN SHOWME THE RESULT IN THE SAME NUMERIC CONTROL.
(2,611 Views)
If you need to be able to change it manually, it always needs to be a control. You can always modify it programmatically by writing to a local variable of it.
(2,590 Views)
