How to use the High Throughput Division to handle fixed array in the SCTL
Hello! The hardware is PXIe-1071 and PXIe-5170r
I get four channel fixed Aarray from the sample data in just the pic following
After the collection of data I want to handle it with high throughput division. But it don't support array
I have tried the for loop with Autoindex but high throughput division can't use in the for loops in the SCTL
(3,616 Views)
Use the index array to get each element seperately and implement 4x high throughput division separately.
What clock rate does the data arrive at?
(3,606 Views)
I want the data after high throughput division to be array again
The way like this may not achieve this
The clock rate is Date clock .the rate of the collection is 250Ms/s.
(3,599 Views)
(3,598 Views)
Are you always going to divide by a constant?  If so, then multiplying by 1\constant is much more efficient.
Also, you need to have the 4x division in PARALLEL, not in series.  Before, you index array, after you build array.
(3,593 Views)
I want one array to divide one array in the SCTL use high-throughput division
But use index ,I can get just one element of array.
I have tried use for loop to use like a counter to increase the index number to get all elements,
Just like this but it's only get one element too.
(3,556 Views)
