How to use the Occupancy grid block
Hi everybody, I was looking for related examples in labview with any sensor and the Occupancy grid Map block, but, I couldn't find anything, only some simulations.
I would like to know if somebody have tried to use it with the data from a sensor in order to build a map.
"Everything that has a beginning has an end"
(3,346 Views)
Hi anfedres86,
  I don't know of any examples like that off the top of my head, but I'll continue to work to find a solution or example that might help you out.
Austin S.
Academic Field Engineer
(3,322 Views)
Hi Austin, I would like to share with you and with the NI community a Video that I made today, showing the Real Occupancy grid Map Algorithm working on Labview, I going to publish the code soon, I need to fix some bugs first.
http://www.youtube.com/watch?v=-KXQ750qAWA
Regards
Andrés F. E.
(3,272 Views)
Andres,
Nice...thanks for posting that!  That is something that will be very useful for future similar issues.  I look forward to taking a look at the code you used for this whenever you publish it.
Austin S.
(3,256 Views)
