How to use the Tab Control class?
NXG.
Newbie here.
I am trying to use the tab control to keep a history of the last twenty data collection events. My thought was to add new tabs using code as I collect data, once I reach 20 then start shifting the oldest off first. When I add a tab control to my panel and then go to code and insert the new tab control into my dode I get a type I32. If I try to wire the new tab to properties I am told there is a type mismatch.
What is wrong here?
I am thinking that there might be a way to programatically add and remove tabs in a tab control. Will a tab control do what I think it might do?
(1,916 Views)
No. A tab control is a UI element, not a storage device.
A good way to store data is a shift register containing a fixed size array where you can replace elements as you go. Can you attach some simple code so we can see what you are trying to do?
(1,874 Views)
@flycast wrote:
What is wrong here?
I don't know if they've changed it in NXG, but in standard LV you can't add tabs while running. You have to create all 20 Before hand and can hide/show as needed.
Qestit Systems
Certified-LabVIEW-Developer
(1,819 Views)
