How to use the ascii code
I have a hardware which could't communicate with ascii code , so as I recive the data from the hardware , the data is just a hexadecimal number , but LabVIEW will automatically transform it to a character , now I want to use the original data , how can I solve the problem?
Thanks a lot!
(3,228 Views)
Your statement is very difficult to fully understand.
Do you mean that you have suceeded in communicating with the hardware device?
If you have recieved the data from the hardware then maybe you should save to disk so that you can then analysis the protocol codes.
Please clarify 1
xseadog
(3,215 Views)
This may help
http://forums.ni.com/attachments/ni/170/239858/1/hex_fun.JPG
Message Edited by James R on 04-06-2007 09:40 AM
- James
Using LV 2012 on Windows 7 64 bit
(3,203 Views)
You could try using Type Cast
Message Edited by tbob on 04-06-2007 09:47 AM
- tbob
Inventor of the WORM Global
(3,189 Views)
