How to use the "Get Shared Variable List" VI on an RT target?
I'd like to programatically iterate through all the shared variables in a library hosted on my CompactRIO. I dropped the "Get Shared Variable List" VI into my Real-Time VI, but when I tried deploying it, LabVIEW said
Deploying PRC_GetVarList.viPRC_GetVarList.vi loaded with errors on the target and was closed.
LabVIEW: Failed to load shared library dscProc.dll:ni_lvdsc_process_GetTagListEnd:C. Ensure that the library is present on the RT target. Use MAX to install NI software or FTP to transfer custom libraries to the RT target.
LabVIEW: Failed to load shared library dscProc.dll:ni_lvdsc_process_GetTagListBegin:C. Ensure that the library is present on the RT target. Use MAX to install NI software or FTP to transfer custom libraries to the RT target.
I looked at the MAX Software Wizard, but couldn't find any DSC-related modules. Where should I be looking?
Thanks!
Certified LabVIEW Developer
(3,140 Views)
Accepted by topic author JKSH
The DSC palette is not supported on Real-Time VIs and will lead to errors when deployed.  Unfortunately, to have a successful build you will need to modify your application and remove any of the VIs from the DSC palette on your RT Target.
M. Whitaker
ni.com/support
(3,123 Views)
