How to use virtual device ID with sound function?
We use N computing devices which allow us to acess one desktop by many users. We came across a problem while  recording sound through these  N
Computing devices because sound function gives an error of invalid device iD. Please suggest a solution.
(3,685 Views)
Can you elaborate. Perhaps post your code or part of it to show the problem
Ps by code I do NOT mean some picture of your coding 😉
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(3,676 Views)
My problem is with the virtual device ID because on a standalone computer this vi doesnt give an error message. Problem is with its use on N
computing device.
(3,673 Views)
computing device.
(3,673 Views)
Are you using this program on PDA or standard windows PC
(3,669 Views)
am using standard Windows PC
(3,661 Views)
Have you solved your problem? Go to help in the toolbar. Then select Find examples. Do a serch for sound and loacate the "Sound Input to File.vi" example. That should give you a push in the correct direction
(3,635 Views)
