How to validate Syntax in string format
Hello all,
I need small help. Please help me.
I want to validate some syntaxes like below. Is there is any default LabVIEW function for this?
OK Type:
(((1 AND 2) OR 3) OR 4)
(((1 AND 2) OR (3 OR 4)) OR 5)
NG Type:
((1 AND 2) OR (3 OR 4) OR 5)
(( 1 AND 2 OR 3) OR 6)
(1 AND 3 OR 3
I need to check above syntax is correct or not (like brackets are properly opened & closed, AND/OR etc.).
I created sample VI for this but in some cases it is giving wrong result (eg: ((1 AND 2) OR (3 OR 4) OR 5)) .
Munna
Message 1 of 10
(6,008 Views)
Brackets should be easy enough - the number of times "(" appears" is the same as ")" and the first and last instance of each must be those respectively.
Message 2 of 10
(5,999 Views)
we cant judge syntax only by open & close bracket.
For example. ((1 AND 2) OR (3 OR 4) OR 5)
Here "(" count is same as  ")" but it is NG case.
Correct Synatax: (((1 AND 2) OR (3 OR 4)) OR 5)
Munna
Message 3 of 10
(5,992 Views)
For example. ((1 AND 2) OR (3 OR 4) OR 5))
Correct Synatax: (((1 AND 2) OR (3 OR 4)) OR 5))
Your NG example has 3 "(" and 4 ")". So I'm not sure I understand your point. But you also haven't clarified what rules you are trying to enforce or any other context for your question. Until you do I don't think I can help.
EDIT - I see you have updated your example to fix the last ")". But I still don't understand what you are trying to achieve. If 1 to 5 are boolean inputs then your NG example is perfectly valid boolean arithmetic syntax. You need to provide a better context for what you are trying to achieve.
Message 4 of 10
(5,987 Views)
State your requirements... as a set of requirements!  Not only will it help us, but you may come up with the solution yourself.
Bill
CLD
(Mid-Level minion.)
Message 5 of 10
(5,958 Views)
Hello Tyk007,
Sorry for the confusion.
1 to 5 are Boolean but we want to do logical operation for only two at once.
For example:
(1 OR 2 OR 3) à this is correct for logical operations. But we want to do two at a time.
It means ((1 OR 2) OR 3) , other way (1 OR (2 OR 3)).
So, if user is giving syntax like (1 OR 2 OR 3), we need to make it NG type. Like this I need to check different combinations to validate the syntax.
Munna
Message 6 of 10
(5,956 Views)
This might be one of those times where telling us "why" you need to have it done is more valuable than "what" you want done.
Bill
CLD
(Mid-Level minion.)
Message 7 of 10
(5,943 Views)
Part of you problem is that some of the disallowed cases are logically correct. A two-step approach might work well. Step 1 would be to check for logical correcteness. Step 2 would be to insure that the syntax matches whatever arbitrary rules are imposed.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 8 of 10
(5,928 Views)
Here is updated code.
I'm really sorry if my required is not clear.
Please let me know where your getting confuse.
Munna
Message 9 of 10
(5,924 Views)
I did little modifications.
I think it will cover all combinations.
Please let me know if there is any modifications required.
Munna
Message 10 of 10
(5,895 Views)
