How to view each channel in ljstream in different graph
Hi, I am a biginner in labview.
I want to record some ECG tracings using the Ljstream with a labjack U3 but I would like to view two recordings at the same time in two differeny graphs. Please tell me how can I do that?
Thanks a lot
Dragos BARGLAZAN
(2,588 Views)
I would start with the example "U3 Stream Simple Example.vi".  You can see that it passes a 2D array to the Waveform Graph.  If you want 2 graphs instead, split this array as desired and pass the resulting 1D or 2D arrays to multiple graphs.  I would look at the LabVIEW Help for graphs for some background info.
(2,582 Views)
